Discussion forum
CAD discussion |
problem to autocad2010 |
Post Reply |
Author | |
alessio26
Newbie Joined: 08.Sep.2010 Location: Italy Using: AutoCAD2010 Status: Offline Points: 2 |
Topic: problem to autocad2010 Posted: 08.Sep.2010 at 15:04 |
hi
i have this problem:
ERRORE IRREVERSIBILE: Unhandled Access Violation Reading 0x705bc003 Exception at 4ac7330h
soultion please
Cad64
Senior Member Joined: 17.Apr.2010 Location: United States Using: Autocad 2011, 3DS Max 2011, Photoshop CS5 Status: Offline Points: 491 |
Posted: 08.Sep.2010 at 15:41 |
Well, you're going to have to provide a lot more information.
For starters: What are you doing when this error occurs? What are your full computer specs? Does this happen all the time or only in certain drawings? Have you loaded update 1 and update 2 for 2010? The more information you provide, the easier it is to identify what the problem might be. |
Online Portfolio: http://www.rdeweese.com/
alessio26
Posted: 08.Sep.2010 at 16:30 |
What are you doing when this error occurs? save the file
Does this happen all the time or only in certain drawings? only in certain
drawings
Cad64
Posted: 08.Sep.2010 at 19:03 |
So it happens when you are saving the file and it only happens in certain drawings? Sounds like a problem with the drawings, not with Autocad.
Purge and Audit the problem drawings and see if that helps. Edited by Cad64 - 08.Sep.2010 at 19:04 |
Post Reply | |
Tweet
This page was generated in 0,539 seconds.
