Discussion forum
CAD discussion |
U.C.S. issues with AutoCAD 2007 Registered |
Post Reply |
Author | |
ad56
Newbie Joined: 07.Feb.2008 Location: United States Status: Offline Points: 7 |
Topic: U.C.S. issues with AutoCAD 2007 Registered Posted: 26.Mar.2008 at 16:55 |
Hold on. I figured it out.... The first response was close. I typed snap. In my version of cad(2007 registered) the following options come up(on/off/aspect/style/type).
I typed rotate, even tho it wasn't one of the options, then it asks you for a base point, I just typed 0,0. Then it asks you for rotation, I typed 90 and that solved the problem..... Thanks for the help! |
Beginner Draftperson-AutoCAD 2007 registered.
ad56
Posted: 26.Mar.2008 at 16:12 |
Still didn't resolve the problem. It's not a big deal, it's just annoying. When I follow those steps, and type plan, it zooms out and the cross hairs don't change. The particular drawing I'm working with, the cross-hairs are off angle in the paper space also, so I'm thinking ucsman won't resolve the issue. (you have to be in model space). I wish I can post a screen shot.
ad56
Posted: 20.Mar.2008 at 19:36 |
Ok, UCSMAN I believe is the answer, but my problem isin't solved yet. When I type ucsman, goto settings, click the update view box,typing plan won't work b/c i guess my viewport is locked. When I unlock the viewport, then double click inside to type plan, as soon as i click inside it zooms out. I typed plan and it still didnt rotate my cross-hairs back to north and south.
I think your advice is a step in the right direction tho, b/c other figures within the drawing are normal, (cross-hairs are north and south) which leads me to believe it has something to do with the viewports. I will go over your steps a few more times, try some new things and get back to you... thanks for the advice... |
bcbenton
Groupie Joined: 11.Mar.2008 Location: United States Status: Offline Points: 45 |
Posted: 14.Mar.2008 at 16:13 |
There is a display setting that will rotate the WCS to match any rotation in a view. This allows as you said, to be in WCS but have the axis rotated on the screen. Try this:
type in : ucsman go to the settings tab: at the bottom of the window, turn on the "UPDATE VIEW TO PLAN WHEN UCS IS CHANGED" options. Click OK type in: PLAN select the WORLD option the screen should rotate back. Now unless you go back in the UCSMAN, your screen will rotate with your ucs rotation. So you might want to go back and turn the display setting off. Let me know how it works. |
For AutoCAD Tips & Tricks
CAD-a-Blog |
ad56
Posted: 13.Mar.2008 at 20:43 |
i checked the snapping. its currently off but set to rectangular snap. I encounted another site plan, in this case, the snapping is even off in paper space, usually its off only in model space. any idea?
Arben.Allaraj
Senior Member Joined: 14.Nov.2007 Location: Albania Using: AutoCAD 2008 Status: Offline Points: 602 |
Posted: 08.Feb.2008 at 11:28 |
Welcome to CADFORUM.
Check the snapang?
Because snap style is Isometric.
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com |
ad56
Posted: 07.Feb.2008 at 16:56 |
The draftpersons before me who worked at my company messed up the U.C.S. in a few site plans and I want to know how to fix.
(Problem)-When I enter model space, the cross-hairs are rotated, but the UCS is normal(x=0,y=90) My guess is that the person changed the UCS so that when they use the rectangle command, it will be on the same plane as another object, or property line. I try changing my UCS to world view, but this does nothing, probably b/c the UCS is already normal. How do I get the UCS and the Cross-hairs back to normal (x=0,y=90)??? I only use 2D. Edited by ad56 - 07.Feb.2008 at 16:57 |
Post Reply | |
Tweet
This page was generated in 0,455 seconds.
