Discussion forum
CAD discussion |
System Variable Settings |
Post Reply |
Author | |
Muqq
Newbie Joined: 07.Nov.2010 Location: India Using: AutoCAD 201 Status: Offline Points: 3 |
Topic: System Variable Settings Posted: 07.Nov.2010 at 08:44 |
Hi Every one,
I'm using autoCAD 2010 since few days in my cad when opening new file or restart of autocad system variable values are becoming '0' egg. fill mode, mbutton pan , zoom factors this types of command going to 0 i try to reinstall autcad then also problem not solve and when i reset the system variable values untill i close restart of autocad or open nay other cad file its ok after i open any cad file or restart of autcad its same problem please any one can help me to solve this problem this irritating me thanks |
Cad64
Senior Member Joined: 17.Apr.2010 Location: United States Using: Autocad 2011, 3DS Max 2011, Photoshop CS5 Status: Offline Points: 491 |
Posted: 09.Nov.2010 at 02:22 |
Are you using any custom lisp routines that are loading at startup?
Are you running any 3rd party add-on programs with Autocad? |
Online Portfolio: http://www.rdeweese.com/
Muqq
Posted: 09.Nov.2010 at 08:49 |
CAD64 Thanks for your reply,
I'm not using any lisp files and 3d add-on program, please give me solution waiting for that, thanking you, Edited by Muqq - 09.Nov.2010 at 08:49 |
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2018 |
Posted: 09.Nov.2010 at 08:58 |
Your user profile is being probably reset on each AutoCAD launch (using some custom mechanism) or you have no read/write access to your profile.
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
honeycrippen12
Newbie Joined: 11.Nov.2010 Location: United States Using: autoCAD2010 Status: Offline Points: 1 |
Posted: 11.Nov.2010 at 10:41 |
System variable setting is also one of big issue,well u all have discussed well about it and I really appreciate with that.
Thanks for sharing it Disaster Recovery Plan |
Post Reply | |
Tweet
This page was generated in 0,391 seconds.
