CZ | EN | DE
Login or
registration
  Visitors: 7304
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedARIAL FONT PROBLEM
 Post Reply Post Reply
Author
adeelcad View Drop Down
Newbie
Newbie
Using: autocad2008
Status: Offline
Direct Link To This Post Topic: ARIAL FONT PROBLEM
    Posted: 22.Mar.2011 at 07:42
Hi,
i m using autocad 2008. i m using pdf-xchange 3 here is some problem to make a pdf. i m use arial font.
some text and dimensions show good but some text and dimensions show bold.
i use flatten command all text show good but dimensions are not changed.
plese advice me what can i do.
Regards,
Adeel
adeel
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 22.Mar.2011 at 10:47
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: autocad2008
Status: Offline
Direct Link To This Post Posted: 23.Mar.2011 at 07:25
i can check but my problem is not solve. kindly any other solution.
adeel
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 23.Mar.2011 at 10:48
Try using the old CHANGE command.  The option you need to use is called ELEVATION.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: autocad2008
Status: Offline
Direct Link To This Post Posted: 23.Mar.2011 at 10:54
i can apply change command but dimension text are not changed.
adeel
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 23.Mar.2011 at 11:10
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: autocad2008
Status: Offline
Direct Link To This Post Posted: 23.Mar.2011 at 12:18
yes sir...................
all dimensions are changed..........
thank you very much sirrrrrrrr.......
adeel
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 23.Mar.2011 at 12:30
Glad to hear it.  Next time though try sticking to one thread rather than starting two threads on the same subject.  It makes it a lot easier to follow.  :)
<<AutoCAD 2015>>
Back to Top
lyssagale12 View Drop Down
Newbie
Newbie
Using: AutoCAD2012
Status: Offline
Direct Link To This Post Posted: 30.Jun.2011 at 10:04
Thank you Jone Connor for you solutions !!!
Lyssa Gale
Language Fonts
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,441 seconds.
