Discussion forum
CAD discussion |
line and polyline? |
Post Reply |
Author | |
kelvin.loh
Newbie Joined: 17.May.2011 Location: Singapore Using: autocad 2010 Status: Offline Points: 12 |
Topic: line and polyline? Posted: 18.May.2011 at 03:56 |
Generally whats the difference between the 2?
On what situation should i use polyline? can i convert line into polyline?
What can line do that polyline can't?
Vladimir Michl
Posted: 18.May.2011 at 08:29 |
Line is just one straight segment, Polyline is a series of segments (lines or arcs). Line can be 3D, plain Polyline cannot (there are also 3DPolylines).
You can convert Lines to Polylines (e.g. with PEDIT) and Polylines to Lines (with EXPLODE).
Vladimir Michl (moderator)
kelvin.loh
Posted: 18.May.2011 at 09:48 |
thanks |
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 18.May.2011 at 11:57 |
A rectangle created with the line command consists of four separate entities. The sample rectangle created with one continuous polyline would be treated by AutoCAD as a single entity. Polylines, via the Pedit command, can also be turned into splines and can have curves fitted to them.
<<AutoCAD 2015>> |
heinsite
Senior Member Joined: 05.Feb.2009 Location: United States Using: AutoCAD 2014 Status: Offline Points: 640 |
Posted: 19.May.2011 at 05:49 |
It's often more what a closed polyline object can do that a series of individual line segements cannot: Provide direct computation of perimeters and areas. Those can be worth the price of admission alone.
Dave Hein, P.E.
Hawaii District Engineer Kona International Airport AutoCAD Certified Professional Autodesk Expert Elite |
jirachai
Newbie Joined: 19.May.2011 Location: Thailand Using: 2008 Status: Offline Points: 3 |
Posted: 19.May.2011 at 10:30 |
The distinction between line and polyline is. line = 2D = ok. and can convert polyline by command explode. Therefore if you use just drafting 2D will not have to use the polyline. |
John Connor
Posted: 19.May.2011 at 11:43 |
Avoiding the use of polylines in 2D drafting is not a good CAD drafting practice.
<<AutoCAD 2015>> |
ChristianD
Newbie Joined: 18.Jan.2011 Location: United States Using: AutoCAD2010 Status: Offline Points: 3 |
Posted: 23.May.2011 at 11:55 |
Hi, The original Polyline in AutoCAD while a vast improvement over having to use line segments and arcs was a resource hog. each vertex and end were separate entities so a Polyline with two vertexes was four entities. In r14 AutoCAD introduced the lwpolyline (lightweight polyline) which was a single entity. For drawing which included lots of contours or other complex polylines drawing sizes shrank considerably. Big difference in speed and stability as well. Thanks!
________________ pest exterminator |
Post Reply | |
Tweet
This page was generated in 0,613 seconds.
