Discussion forum
CAD discussion |
Free Cad Blocks |
Post Reply |
Author | |
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Topic: Free Cad Blocks Posted: 04.Jun.2011 at 13:10 |
You make a block in a drawing using the BLOCK command. If you want to use the same block in other drawings then consider using the WBLOCK command instead. AutoCAD will write the block definition as a drawing file to your hard drive. Then use the INSERT command and bring the block into your drawing. It is recommended that blocks be created on layer "0" so that when they are inserted they take on the properties of the layer they are being inserted on. This would be such things as color and linetype for example.
<<AutoCAD 2015>> |
John Connor
Posted: 04.Jun.2011 at 13:06 |
What exactly is wrong with your render? Too dark? Too light? Materials are displaying as you expected? We need more information.
<<AutoCAD 2015>> |
mgaungthetoo
Newbie Joined: 04.Jun.2011 Location: Myanmar Using: AutoCAD2010 Status: Offline Points: 2 |
Posted: 04.Jun.2011 at 12:53 |
my render photo is no same in the model space cso why do i made sitting
please enplane to me |
mgaungthetoo
Posted: 04.Jun.2011 at 12:50 |
hello
sir how do i made block to my drawing thank |
Cad64
Senior Member Joined: 17.Apr.2010 Location: United States Using: Autocad 2011, 3DS Max 2011, Photoshop CS5 Status: Offline Points: 491 |
Posted: 02.Jun.2011 at 21:24 |
You know, this is the third time you've posted an advertisement for your website. Do you have any intention of joining in and helping out around here with answering questions or are you just here to spam us?
And yeah, were are the 180,000 blocks? |
Online Portfolio: http://www.rdeweese.com/
John Connor
Posted: 02.Jun.2011 at 12:37 |
180,000 details and blocks?
Looks to be less than 180. Where did you hide the remainder? |
<<AutoCAD 2015>> |
cadenvisions
Newbie Joined: 19.Apr.2011 Location: United States Using: Autocad 2012, Desktop 3.3 Status: Offline Points: 3 |
Posted: 01.Jun.2011 at 21:51 |
Download completely free. No uploading necessary.
http://cadenvisions.com/FREEAUTOCADDETAILDOWNLOADS.aspx |
Post Reply | |
Tweet
This page was generated in 0,418 seconds.
