Discussion forum
CAD discussion |
How to open Auto CAD file Read Only... |
Post Reply |
Author | |
PUNITHKT
Newbie Joined: 19.Mar.2012 Location: India Using: AUTOCAD2012 Status: Offline Points: 1 |
Topic: How to open Auto CAD file Read Only... Posted: 19.Mar.2012 at 11:40 |
HI, How can i open Auto CAD files Read Only (Externally) ... Any Sugguesstion Edited by PUNITHKT - 19.Mar.2012 at 12:05 |
Regards, Punith T Kenchol Graduate - Building Design ATKINS, Bangalore Email: Punith.Kenchol.atkinsglobal.com Web: www.atkinsglobal.com |
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 19.Mar.2012 at 16:25 |
You would have to find the file using Windows Explorer and remove the read-only attribute. Instructions can easily be found on the Internet. Are you on a network? Does someone else have the file open?
You could open the file as read only then do a "saveas" under a slightly different file name. |
<<AutoCAD 2015>> |
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2018 |
Posted: 19.Mar.2012 at 17:33 |
There are multiple options to do this - see the tip:
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
Post Reply | |
Tweet
This page was generated in 0,426 seconds.
