CZ | EN | DE
Login or
registration
  Visitors: 4987
Plex.Earth connects AutoCAD and Google Earth
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedLinetype problem
 Post Reply Post Reply Page  12>
Author
zippypinhead View Drop Down
Newbie
Newbie
Using: AutoCadR14
Status: Offline
Direct Link To This Post Topic: Linetype problem
    Posted: 04.Apr.2012 at 04:23
Help!
I have another glitch showing up tonight... No matter what layer I'm on and what linetype it's set to, everything is coming out as a "HIDDEN2" linetype. For now, to finish the dwg. I'm just using the match properties paintbrush to fix things.
It's only happening on the current dwg. If I open something else, everything works as normal.
I figure I fat fignered something but have no idea what...
AutoCad2011-I've been using it for almost a year now without this particular gremlin.
Thanks in advance.
Robin
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 04.Apr.2012 at 11:46
Did you check that the linetype is set to "By Layer"?  Sounds like it has been overridden.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AutoCadR14
Status: Offline
Direct Link To This Post Posted: 04.Apr.2012 at 13:34
Thanks for that....
Now I'm wondering how the heck I ever fat fignered the change.... seems to take quite a few really specific keystrokes.
AGain, thanks for the quick reply. It really did help.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 04.Apr.2012 at 18:08
Not sure how you managed it.  Did you happen to use a custom lisp routine lately?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AutoCadR14
Status: Offline
Direct Link To This Post Posted: 05.Apr.2012 at 04:48
Hell, I don't even know what a lisp routine is. Much less a custom one.Wacko
Although I've been using versions of AutoCad for almost twenty years, I'm a cave man. I tend to only learn enough to get my work done.... When I have projects stacked up, (like now) a 70 hour workweek is like a vacation....
Back to Top
heinsite View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 05.Apr.2012 at 06:16
If you didn't run a LISP routine then you probably did a linetype override earlier in your work and just forgot about it.
Strange things happen when we get in a hurry! Ouch
Dave.
Edited by heinsite - 05.Apr.2012 at 06:17
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 05.Apr.2012 at 12:14
Lisp is a programming language.  Some lisp routines are included with full AutoCAD.  Example: FLATTEN which can be found in Express Tools.  I'm very surprised that someone who has used AutoCAD for 20 years has not heard of AutoLisp or Lisp.
<<AutoCAD 2015>>
Back to Top
dragona View Drop Down
Newbie
Newbie
Using: AutoCAD2007
Status: Offline
Direct Link To This Post Posted: 11.Apr.2012 at 11:23
Or you can restart the computer, then empty the cache to try?
I heart which I could not help him
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 11.Apr.2012 at 11:50
The "empty the cache" trick will not solve a linetype problem.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 11.Apr.2012 at 23:09
Is this happening in *every* file you work on now, or just in this one particular file?
Have you run an AUDIT or a RECOVER operation on this problem file?
Dave.
Dave Hein, P.E.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,404 seconds.
