CAD Forum - Database of tips, tricks and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
  Visitors: 5356
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedHow to draw an irregular rectangle ??
 Post Reply Post Reply
Author
lovejeevan View Drop Down
Newbie
Newbie
Using: auto cad 2006
Status: Offline
Direct Link To This Post Topic: How to draw an irregular rectangle ??
    Posted: 31.Mar.2013 at 16:33
Hi all,
I wish to draw an irregular rectangle. I know the measurement, but where as i dont know the angle. how to draw an irregular rectangle without angles.
please help.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 01.Apr.2013 at 01:01
Draw the diagonal then use intersecting circles drawn from the endpoints.
<<AutoCAD 2015>>
Back to Top
heinsite View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 01.Apr.2013 at 06:18
If these are the only measurements you have then I don't see that you have enough information to draw the object.
Dave.
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 01.Apr.2013 at 06:19
Try it, John.  I don't see enough aligned dimensions.
Dave.
Dave Hein, P.E.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 01.Apr.2013 at 12:00
I can reproduce the rectangle with one exception.  The 86'-10" distance ends up being closer to 86'-3".
What is the source of the distances used?
Why is the rectangle being constructed in this manner?  In other words, why no angles?
Edited by John Connor - 01.Apr.2013 at 12:01
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 01.Apr.2013 at 14:23
You're a better man than I, John.  But I bet it was more work than you bargained for.
Let's not call this a rectangle anymore however, let's call it what it is:  a Quadralateral.
Dave.
Dave Hein, P.E.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 01.Apr.2013 at 18:09
It took less than 30 seconds.
<<AutoCAD 2015>>
Back to Top
CarlB View Drop Down
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 01.Apr.2013 at 18:17
I agree with Heinsite, difficult or possibly not enough information. Only way to draw it easily is asume alldimensions are aligned, although some clearly appear to be horizontal/vertical. Probably why John's result didn't match the "given".
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 02.Apr.2013 at 11:32
Let's see...yep, I came closer than either one of you!  LoL
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 02.Apr.2013 at 11:58
lovejeevan: What is the purpose of this exercise?
It's not the sides that are the problem.  It's the fact that you cannot get both diagonals to match the given dimensions easily.  You can get one or the other to match but you're left with the other diagonal being short.
Maybe the solution requires constructing the rectangle using constraints?
Edited by John Connor - 02.Apr.2013 at 12:15
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,457 seconds.
