Discussion forum
CAD discussion |
Solid, not hollow |
Post Reply |
Author | |
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Topic: Solid, not hollow Posted: 22.Apr.2013 at 11:51 |
Changing one's visual style does NOT turn an object into a true 3D solid.
imtrying: So what exactly did you end up with? Surfaces? Did you try one of the "Convert to..." commands or the SurfSculpt command? |
<<AutoCAD 2015>> |
Imad Habash
Newbie Joined: 18.Dec.2008 Location: Jordan Using: AutoCAD2016 Status: Offline Points: 17 |
Posted: 22.Apr.2013 at 07:53 |
Change your visual style..
imtrying
Newbie Joined: 22.Apr.2013 Location: Portugal Using: AutoCAD2013 Status: Offline Points: 2 |
Posted: 22.Apr.2013 at 01:52 |
Tryied lofting, but results in just the walls. I want it to be solid, not hollow
help.dwg Edited by imtrying - 22.Apr.2013 at 02:39 |
Post Reply | |
Tweet
This page was generated in 0,336 seconds.
