Discussion forum
CAD discussion |
Complicated Arc Construction |
Post Reply |
Author | |
dery
Senior Member Joined: 31.Jan.2018 Location: United States Using: AutoCAD 2014 Status: Offline Points: 113 |
Post Options
Thanks(0)
Posted: 02.Feb.2024 at 20:03 |
How do you draw by technical drawing/mechanical drafting theory using AutoCAD 2014,
the R2690 arc that tangent to R30 circle at point A, and tangent to R2100 arc at point B, and the R2100 arc is tangent to 3£ line? Thank you Edited by dery - 02.Feb.2024 at 20:04 |
Kent Cooper
Senior Member Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 629 |
Post Options
Thanks(0)
Is the curve from A toward B supposed to have a starting direction of 0 degrees, that is, be tangent to the little R30 Arc at its quadrant point, that is, is the center point of the R2690 Arc direction above A? If so, draw a Circle from that center point using A for the radius, then draw a Circle using the Tangent-Tangent-Radius option, tangent to the first Circle in the vicinity of B and to the 3-degree Line, at the 2100 radius. Trim appropriately. Whether B will end up 90 units below the one Line remains to be seen -- it may not be possible for all dimensions and radii and tangencies to be correct at the same time.
Edited by Kent Cooper - 02.Feb.2024 at 22:24 |
philippe JOSEPH
Senior Member Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1428 |
Post Options
Thanks(0)
Hello Dery and kent, I see parametric constraints shown on your image, this should solve "all" your "problems".
Kent, your explanations won't fullfill the expectations of Dery as he wants a figured out ( on AutoCAD ) step by step drawing like I did on the previous discussion : How to Draw Arc with Known 3 Parameters. Dery, as a student you should invetigate more on those "simples" geometric exercises.
dery
Post Options
Thanks(0)
Hi Mr. Cooper, could you show me by image please. |
Post Reply | |
Tweet
This page was generated in 0,354 seconds.
