Discussion forum
CAD discussion |
An idea |
Post Reply |
Author | |
Arben.Allaraj
Senior Member Joined: 14.Nov.2007 Location: Albania Using: AutoCAD 2008 Status: Offline Points: 602 |
Topic: An idea Posted: 10.Jun.2008 at 10:51 |
Hello Vladimir.
I think is it better for dividing the blocks by their type?
ex: *.ipt to be in Inventor directory , *.dwg to be in AutoCAD directory
just a mention.
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com |
Vladimir Michl
Posted: 10.Jun.2008 at 23:13 |
Thanks for your input.
In fact the Catalog contents is not divided into directories - it is just a database. But you can filter the files (blocks) in a specified format only - see the links on the left or in the heading: DWG, IPT, RFA. You can also select a specific format only (i.e. DWG20004) on the advanced search page.
Vladimir Michl (moderator)
Post Reply | |
Tweet
This page was generated in 0,383 seconds.
