Aktualizace Inventor CAM 2020.1
Název fóra: CAM, 3D tisk a ReCap
Popis fóra: CAM aplikace Autodesk, aditivní výroba a 3D tisk - Inventor CAM(HSM), HSMworks, PowerMill, FeatureCAM, Netfabb; reality-capture nástroje (mračna bodů, foto, 3D sken), aplikace ReCap
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=29125
Datum vytištění: 08.říj.2026 v 09:08
Téma: Aktualizace Inventor CAM 2020.1
Předmět: Aktualizace Inventor CAM 2020.1
Datum odeslání: 12.čvc.2019 v 10:26
Byla vydána aktualizace pro Inventor CAM 2020 (Inventor HSM). Ke stažení je na Autodesk Account. Přehled novinek a oprav:
Milling Toolpaths
Fixed an issue where 3D Adaptive Clearing with rest machining can fail with complex remaining stock. (#13622)
Fixed several issues in which the toolpath computations for Adaptive Clearing could fail on Mac. (#12188)
Improved Adaptive for tighter model contours; it now finds a starting point on the stock boundary. (#12095)
Improved start entries for Adaptive Clearing toolpaths so that the toolpath starts in corners/endpoints rather than in the middle of a stock line. (#12238)
Fixed an issue where calculating a 2D Adaptive toolpath with rest machining from a face selection could result in a large area being machined. (#13030)
Fixed an issue in Adaptive where using a ballnose cutter as a reference tool was giving the wrong toolpath. (#14000)
Removed machine orientation information from the Adaptive toolpath geometry tab. (#14294)
Fixed a crash that could occur in some cases after deleting the contour selection associated with a flat pattern. (#11055)
Fixed an issue where preserve order was not respected in 2D Profile toolpaths. (#12127)
Fixed an issue that could occur when creating bore, circular and threading toolpaths around cylindrical bosses. (#14593)
Fixed a problem in Contour toolpaths where ramps might not be connected to their cutting moves, resulting in an
unexpected lift and plunge to cover the gap. (#13822)
Fixed an issue that introduced unnecessary retracts in Ramp operations. (#13747)
Fixed an issue which caused irregular cutting passes for Scallop toolpaths. (#13757)
Fixed an issue where a Constant Scallop toolpath might not calculate when up/down milling and 'other-way' linking was enabled. (#13172)
Turning Toolpaths
Fixed an issue where an angled turning tool was incorrectly previewed in the tool library. (#13725)
Fixed a problem in turning profile roughing operations with turning mode set to face profiling where the toolpath was not regenerated after the direction parameter in the operation was changed. (#14313)
Added an option for a turn parting operation to keep the parting tool down at the final toolpath point X coordinate or retract it to the clearance X coordinate. (#12779)
Fixed an issue for turning face and chamfer operations with a turning or grooving tool. For certain combinations of the spindle direction and handedness of the holder, the Safe Z coordinate was based upon the wrong side of the insert. (#12454)
Fixed an issue where a grooving operation could fail if the back and front Z limits coincided with the extents of the groove geometry. (#10978)
Fixed a memory leak for some turning grooving jobs. (#13390)
Tool Library
Fixed turning tool preview in the tool library when the spindle rotation was changed. (#13998)
Fixed a problem with the visualization of a round shank external grooving tool in simulation. (#13797)
User Interface
Fixed a problem in which an error message about "invalid machine configuration" was incorrectly displayed. (#14475)
Fixed a problem where retracting z levels were machine areas that had already been cleared in lower levels. (#14035)
Fixed a problem in which stock properties defaulted to selection of faces, and required selecting some face and clearing it before you could select the actual stock. (#13966)
Fixed a crash that could occur when using drag-and-drop to import a tool library from Windows Explorer into the tool library window. (#14382)
Fixed a crash that could occur during simulation if a toolpath removed nearly all of the stock. (#11142)
Fixed a problem in certain operation dialogs that caused incorrect display of group parameters if the group was redisplayed due to a change to another parameter. (#14155)
Fixed a problem that occurred when creating operations from a template containing a Manual NC operation. No tool will be assigned to the Manual NC. (#12703)
Post Processor
Functionality has been restored to the alert, promptKey, and promptKey2 API calls. These now work as before, but are supported only on Windows. (#14452)
Fixed a regression where tool.getExtent() could return an empty bounding box, causing the setup sheet to incorrectly scale the tool image. (#13848)
Added a mechanism to define which rotary axes support TCP in the post processor. This simplifies the code needed to disable TCP for a single axis. (#13282)
Added new global function 'isNewWorkPlane(section)' which returns true if the passed section requires new workplane calls. This simplifies the 'newWorkPlane' checks that are typically done inside of post processors (#13278)
Added global variables 'minimumProgramNumber' and 'maximumProgramNumber' to post processor. (#13276)
Post properties that you set when using a post processor are now saved to a file. This allows using the post processor on other computers with confidence that the previously used properties will continue to be applied. (#13233)
Added the onManualNC function that will handle all Manual NC commands, and the expandManualNC function that handles all Manual NC commands using the historical method. (#12839)
Fixed the behavior of mapToWCS, so that it can be changed multiple times in the post. (#12733)
Added cancelRotation and cancelTranslation methods. (#8965)
NC Editor
Updated HSMEdit to fix an issue in which the display of text was corrupted. (#14524)
Updated HSMEdit to correct a problem with the backplotting function. (#14428)
Licensing
Fixed a problem that could occur when activating Inventor CAM with an HSM Ultimate network license. (#15164)
Fixed an issue in which administrator privileges were required when activating a license. (#14902)
