File Menu of AliasEdit Command
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2659
Printed Date: 27.Oct.2026 at 01:21
Topic: File Menu of AliasEdit Command
Posted By: rahul.cs.rgec
Subject: File Menu of AliasEdit Command
Date Posted: 12.Nov.2009 at 07:58
I want to know the use of creating the new Autocad Alias Editor. After executing the AlliasEdit Cmd. , go to the File menu, and then the New. It will create the Unnamed Autocad Alias Editor. Even I imported a acad.pgp file in it. And added a new alias for one command. And saved that file with xyz.pgp. Now I am trying that shortcut in autocad.,Error of "unknown command" appears.
Again on executing the AliasEdit command, AutoCad is reading the Acad.pgp not xyz.pgp How autoCad will read xyz.pgp. If it cant read xyz.pgp , then whats the use of creating a new .pgp file & import and export options in File Menu. Please reply.
Posted By: CarlB
Date Posted: 12.Nov.2009 at 09:54
I believe AutoCAD will recognize only one pgp file, "acad.pgp". i don't know why there would be an option for "new" in ALIASEDIT.
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2883809&linkID=9240617
