Print Page | Close Window
Plotting Problem
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=573
Printed Date: 06.Sep.2026 at 08:49
Topic: Plotting Problem
Posted By: Natnorth
Subject: Plotting Problem
Date Posted: 19.Mar.2008 at 11:50
My Autocad 2006 has just begun to give intermittent plotting errors. Everything goes fine until the end, when the plot log says 'Job Canceled', although the number of errors and warnings is given as zero.
This does not seem to depend on what printer is being used.
Help Please!
Nat
Posted By: Arben.Allaraj
Date Posted: 19.Mar.2008 at 15:51
Help Please!
Maybe you don't installed correct it should have tip *.pc3 in your lists of printers.
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
Posted By: Natnorth
Date Posted: 19.Mar.2008 at 16:05
Thank you for the suggestion, though I do not think this can be the problem. The program has been installed for several years, and I have not changed it or the printers, and the problem only affects some files - it seems to be file-dependent.
Nat
Posted By: sebgonz
Date Posted: 20.Mar.2008 at 13:24
Have you checked if your plotter is out of memory? Read tip 5519. That sounds similar to your issue.
