Print Page | Close Window
Need help with the roof ( Architecture 2012)
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7544
Printed Date: 30.Oct.2026 at 12:16
Topic: Need help with the roof ( Architecture 2012)
Posted By: miroslav_s
Subject: Need help with the roof ( Architecture 2012)
Date Posted: 21.Mar.2012 at 13:36
Hello to you all,
I need a little help with my roof that I am trying to draw in Autocad Architecture 2012. The house is 8 x 8 m (square) and what I want to draw is a T shaped gable roof. If I make first a hip roof by pulling out the lightblue handles I can transform it to gable roof. If I instead choose from the start that I want a gable roof and point out the corners of my house I get following error message
Problem:
All the sides of the roof are gables
Possible Solution(s):
Use roof slab to create all gable sideroof
I have attached picture showing how I want my roof to look like. A sI said it is a T-shaped gable roof. Can someone please instruct me how to draw this roof?
Thanks in advance and best regards to you all,
Miro
Posted By: John Connor
Date Posted: 21.Mar.2012 at 17:56
I could create one in plain AutoCAD but couldn't tell you what feature to use in Arch 2012.
<<AutoCAD 2015>>
Posted By: heinsite
Date Posted: 22.Mar.2012 at 00:55
And I'm almost embarassed to tell you how long it took to do it in SketchUp!
Dave
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Date Posted: 22.Mar.2012 at 10:33
I was only on my second cup of coffee and not my usual ten so it took me 2.5 minutes to do it in AutoCAD 2012.
<<AutoCAD 2015>>
Posted By: heinsite
Date Posted: 22.Mar.2012 at 12:35
One of the reasons I like SketchUp so much is because it's easy enough for a 3rd grader to learn.  Even something like this can be created in less than a minute.
I'm naturally very excited to see how well AutoCAD and SketchUp (and Google Earth) will play together in the 2013 version.  It should be in mailboxes within the next 2-3 weeks.  Mine arrived last year on 4/11.  The expiration date on the 2013 BETA add-ons is 3/27... so that's a magic day.  It was a SketchUp 2013 add-on beta that tipped me off.
Dave
Dave Hein, P.E.
Date Posted: 22.Mar.2012 at 13:51
It is not a problem for me to do it in Autocad 2012 with simple lines (or using presspull/extrude command) like I showed in the pictures above. But by doing it with simple lines you can not "pull" the light blue handles the way you can do it if you draw the roof with the "roof command" you have in Autocad architecture. The GREAT thing about "roof command" in Autocad Architecture is that you can easily adjust/change the dimensions of the roof. There is the difference my friend.
Thanks anyway but I stick with the Autocad anyway.
Bets regards,
M
Posted By: heinsite
Date Posted: 22.Mar.2012 at 15:08
Since there may only be a few people in this forum who use Architecture you might get more responses over in the Autodesk Discussion Groups:
http://forums.autodesk.com/t5/AutoCAD-Architecture/bd-p/248" rel="nofollow - http://forums.autodesk.com/t5/AutoCAD-Architecture/bd-p/248
Good luck!
Dave.
Dave Hein, P.E.
Date Posted: 22.Mar.2012 at 16:10
Thanks mate, I will check it out. Meanwhile I have downloaded the autocad architecture book so the answer to my question is there somewhere.
Thanks again.
