CAD tip CAD tip # 6737:
Question
When you try to import a AutoCAD DWG file into Autodesk 3ds Max, it reports an "Import Problem":
Unable to open:
MyDrawing.dwg
The error code reported is eNotImplementedYet
The problem is most probably caused by a DWG file format which is not supported in your version of 3ds Max - you are e.g. importing a DWG format of AutoCAD 2010 to 3ds Max 2009.
Save your DWG file in AutoCAD to an older format (with SAVEAS), or convert the file to an older version with the free tool "Autodesk DWG TrueView", or upgrade your 3ds Max to a compatible version.
Also make sure that the filename or its path does not contain non-ASCII characters - e.g. cyrillic or chinese.
max2010max2009DWG
10.6.2009   72332×
this tip shared by ARKANCE experts applies to: 3ds Max 2010 · 3ds Max 2009 · DWG ·
Tip 14833:CAD formats supported in Autodesk VRED 2026.
Tip 14820:3ds Max won't import terrain from Civil 3D.
Tip 14799:7 quick methods to upload your project to Autodesk Docs (Forma Data Management)
Tip 14359:Automatic macro execution when opening a CAD file (AutoCAD, Inventor, Max, PowerMill)
Tip 14310:Easy graphical display of the project or assembly file structure (hidden function).
Back    All CAD Tips
Categ:
