CAD tip CAD tip # 7318:
Question
As you approach to the point when the trial (unactivated) AutoCAD license expires (30 days between the installation and activation of your license), it may be neccessary to activate your license "on the fly", inside a running AutoCAD session (not on the AutoCAD launch).
You can perform the activation with the ABOUT command. Click the buttons About the product > Activate and you'll get to the dialog "Autodesk Licensing", which is usually displayed on AutoCAD startup:
License activation (CZ version)
Click the Activate button in this dialog. If you have received your activation code over e-mail, pick the option I have the activation code from Autodesk and in the numbered fields 1-16 enter the hexadecimal activation code from the e-mail. It is not neccessary to manually type-in the individual fields - just copy/paste the code as a single string (some fields may remain blank). By finishing the activation you will get back to your running AutoCAD session.
License active (CZ version)
ACAD2011ADT2011ACADM2011Civil2011ACAD2010
21.4.2010    69908×
Tip 14718:Activating contextual learning in Eagle Point Pinnacle.
Tip 14307:How do I generate EDU licenses for the Autodesk license server?
Tip 12920:How to set up an account for Autodesk Construction Cloud products?
Tip 11508:AutoCAD problem in Windows 10 Anniversary update (F8 key)
Tip 11303:"Clock Error" when starting Autodesk CAD application.
Back    All CAD Tips
Categ:
Increase your productivity with our set of add-on functions for Autodesk Inventor
Be.Smart T4I More info
