CAD tip CAD tip # 7314:
Question
To add contour labels in AutoCAD Civil3D, use the command AddContourLabeling (multiple contrours, by drawing a line across the whole surface), or AeccAddContourLabelingSingle (single label, on a contour point), or AeccAddContourLabelingGroup (in an interval).
See Surfaces > Add surface labels > Contours, resp. in higher versions the ribbon Annotations > Labels & Tables > Surfaces > Contours.
Labels are drawn in the current contour label style (text height, format, color, layer...). You can also subsequently change the style with Setting in the Workspace palette.
Civil2011Civil2010Civil2008Civil2007
18.4.2010   31296×
this tip shared by ARKANCE experts applies to: Civil 3D 2011 · Civil 3D 2010 · Civil 3D 2008 · Civil 3D 2007 ·
Tip 14851:Shrinkwrap - boundary curve of DWG drawing polylines.
Tip 14820:3ds Max won't import terrain from Civil 3D.
Tip 14436:Conversion of arc polylines to straight-segment polylines (e.g. for GIS).
Tip 11511:Assigning elevations to 2D contours (isolines).
Tip 7852:Put Google Earth maps directly into AutoCAD.
Back    All CAD Tips
Categ:
