CAD tip CAD tip # 7896:
Question
If AutoCAD shows only an empty ribbon after start (no panels nor tabs), its XML menu file (CUI) was probably loaded incorrectly.
You can force reloading of the ribbon by switching the AutoCAD workspace. On the command line, type the command WORKSPACE, confirm the setting of the current workspace by ENTER and enter its name ("?" lists the available names) - e.g. "2D Drafting & Annotation" (or just confirm the preset name). The ribbon will be then reloaded from the CUI, resp. CUIX file.
ACAD2012ACAD2011ACAD2010
6.4.2011   23665×
this tip shared by ARKANCE experts applies to: AutoCAD 2012 · AutoCAD 2011 · AutoCAD 2010 ·
Tip 14359:Automatic macro execution when opening a CAD file (AutoCAD, Inventor, Max, PowerMill)
Tip 14226:Cannot select multiple objects with Shift, ribbon tab "Multiple" is displayed.
Tip 14135:New special code ^] for menu-macros, easy object selection.
Tip 13620:How to quickly rotate the view by 90° in AutoCAD LT?
Tip 13529:How to redefine the behavior of a standard AutoCAD command?
Back    All CAD Tips
Categ:
