Over 1.124.000 registered users (EN+CZ).
CAD tip # 8549:
Question
The coordination application for large data sets - Autodesk Navisworks 2013 directly supports importing of 3D CAD data in the following file formats (newly supported formats of the version 2013 are highlighted):
- Navisworks (nwd, nwf, nwc)
- 3D Studio (3ds, prj)
- AutoCAD - Autodesk RealDWG (dwg, dxf)
- ASCII laser (asc, txt)
- CATIA (model, session, exp, dlv3, CATPart, CATProduct)
- Microstation Design (dgn, prp, prw)
- DWF (dwf, dwfx, w2d)
- FBX (fbx)
- CIS/2 (stp)
- IFC (ifc)
- IGES (igs, iges)
- Inventor (ipt, iam, ipj)
- Faro (fls, fws, iQscan, iQmod, iQwsp)
- Leica (pts, ptx)
- NX (prt)
- Pro/Engineer (prt, asm, g, neu)
- Revit (rvt, rfa, rte)
- PDMS RVM (rvm)
- STEP (stp, step)
- STL (stl)
- SolidWorks (prt, sldprt, asm, sldasm)
- SAT-ACIS (sat)
- Informatix MAN (man, cv7)
- JTOpen (jt)
- Parasolid Binary (x_b)
- Riegl (3dd)
- SketchUp (skp)
- VRML (wrl, wrl)
- Z+F (zfc, zfs)
Navisworks2013
29.3.2012
18380×
this tip shared by ARKANCE experts applies to: Navisworks 2013 ·
