CAD tip CAD tip # 6574:
Question
To calculate (summarize) the total area of selected drawing objects (any type, with the property "Area") and insert the area label into the drawing you can use the free LISP utility by CAD Studio - SumaPloch.
You can download this tool from DL Download
ACAD
10.3.2009   11134×
this tip shared by ARKANCE experts applies to: AutoCAD ·
Tip 14967:The geometry cleanup tool for DWG drawings in AutoCAD 2027.
Tip 14808:How to import a KML/KMZ file from Google Maps, including placemark labels, into AutoCAD Map 3D?
Tip 14699:How to add an attribute to all visibility states in a dynamic block?
Tip 14578:Clipping the captured Bing/Esri map image in AutoCAD.
Tip 14443:Connector, notch, groove, cutout or other curve- breaks - easily with dynamic blocks.
Back    All CAD Tips
Categ:
