CAD tip CAD tip # 6748:
Question
During an edit operation AutoCAD displays an alert box:
AutoCAD Warning
This operation may take a long time.
To greatly improve performance, the system can disregard Draw Order.
Disregard Draw Order for this operation?
This warning (dialog) may break your script, macro or a batch operation performed on a large drawing. It can be displayed during the commands BREAK, FILLET, HATCH, HATCHEDIT, EXPLODE, TRIM, JOIN, PEDIT and OFFSET.
If you want to avoid this risk, set the DRAWORDERCTL variable to 0.
ACADACLTADTCivilACADM
22.6.2009   22872×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD LT · AutoCAD Architecture · Civil 3D · AutoCAD Mechanical ·
Tip 14991:Changing the order of rows in a table - sorting tables in AutoCAD.
Tip 14942:How do I place specific types of entities on a specific DWG layer? (LAYER variables)
Tip 14869:How to generate a Regression curve through a set of points in AutoCAD or other CAD?
Tip 14537:Automation of AutoCAD drawing texts using fields.
Tip 14039:How to display the total volume or surface of 3D solids in DWG?
Back    All CAD Tips
Categ:
