CAD tip CAD tip # 9212:
Question
Using a combination of freeware tools you can easily schedule and export XY coordinates of all line intersections in a DWG drawing.
You will need the tools INTLINES and P2BLK (see Download), plus the dynamic label block PtLabel (see Blocks). Load both downloaded LISP utilites with APPLOAD and insert the block PtLabel.dwg into your drawing.
Then start a combination of INTLINES and P2BLK commands, optionally followed by DATAEXTRATION (of course you can also extract the points alone).
See the detailed procedure in the video:
ACAD
20.4.2013   19684×
this tip shared by ARKANCE experts applies to: AutoCAD ·
Tip 13944:Intersection of a 3D spline with a plane in Fusion 360.
Tip 13150:How to hatch selected objects including overlays and islands?
Tip 13087:3DintCurves - intersections of curves with 3D solids.
Tip 12836:How to suppress snapping when inserting symbols and families in Revit?
Tip 12766:Lines with a single grip, incorrect osnaps, intersections, offsets, hatches - CheckLarge
Back    All CAD Tips
Categ:
