Over 1.127.000 registered users (EN+CZ).
CAD tip # 10799:
Question
AutoCAD Civil 3D has no standard method for exporting automatically generated tables (both dynamic and static) nor for their conversion (explode) to standard AutoCAD tables. This applies to volume tables, point tables, alignment tables, surface analysis, etc.
But you can perform export of such tables using freely downloadable add-ons from Autodesk App Store - e.g. with the application Civil Table Export. This add-on tool will export any table with a single click to the CSV format which can be opened e.g. in Excel and processed there.
Civil
16.3.2016
28792×
this tip shared by ARKANCE experts applies to: Civil 3D ·
