CAD tip # 6792:
Question
You can add any 2D or 3D dimensions to a 2D or 3D view in Inventor.
Create a 3D view (e.g. isometric, rendered) on your drawing sheet. Go to the Annotation panel/ribbon and start the Dimension command. You can pick any geometry or points to add linear, angular or radius dimensions to your part or assembly model.
Inventor
14.7.2009
36766×
this tip shared by ARKANCE experts applies to: Inventor ·
