CAD tip CAD tip # 10719:
Question
To add and automatically updated name of the unfold rule (used to unfold a sheetmetal part) to a drawing of a sheetmetal part, you can use the following procedure. To add labels with parameters of the individual unfold edges, use the function Annotate > Elements > Unfold.
In sheet metal model part (folded) go to iPropertes and on the Custom tab add a new text property (e.g. "UnfoldRule"), as its value enter the text (expression):
=<Sheet Metal Rule>
Exit iProperties.
In the drawing then add a text note, in the Format Text dialog box select Custom Properties - Model in the Type dropdown selection field, and specify your newly added property, e.g. "UnfoldRule".
Inventor
28.1.2016   8004×
this tip shared by ARKANCE experts applies to: Inventor ·
Tip 14923:How to model a diagonally stiffened sheet metal, crossbreak in Inventor?
Tip 14569:The extent of the sheetmetal unfold rounded to integer numbers.
Tip 12416:How to export DXF outline of unfolded sheetmetal in Fusion 360, with no bending lines.
Tip 12411:How to wrap text on a cylinder or a general 3D surface in Fusion 360?
Tip 12392:Export unfolds of sheetmetal parts to DXF - parameters for iLogic and VBA
Back    All CAD Tips
Categ:
