CAD tip CAD tip # 9788:
Question
With the freeware utility CADstudio ImportCoord for Inventor, you can read 2D and 3D sketches or work points defined by XYZ coordinates from Excel. If you check the options "3D points" and "Use names" and specify the Excel column number containing point names, the imported workpoints will be named accordingly from Excel.
Download the free ImportCoord utility from ImportCoord. After you load the IVB project into Inventor (VBA Editor), run the VBA macro with Alt+F8.
Excel source Imported workpoints
Inventor
17.4.2014   10592×
this tip shared by ARKANCE experts applies to: Inventor ·
Tip 2231:How to read a coordinate list into Inventor (sketch)?
Back    All CAD Tips
Categ:
Generate hatch patterns automatically from your DWG drawings with
HGEN 2006 More info
