Over 1.127.000 registered users (EN+CZ).
CAD tip # 6799:
Question
There are several approaches for making parts of your AutoCAD drawing "inactive" - i.e. not including it into osnaps, hatch borders, etc.
- You can lock some layers - locked layers do not participate on edit operations.
- You can WBLOCK some parts of your drawing, erase them and reattach them as an Xref. Attached xrefs can be suppressed.
- You can publish your drawing to a DWF file and reaattach it (at the same coordinates) as an underlay with the DWFATTACH command. The DWFOSNAP variable controls the object snaps on DWF "entities".
ACADACLTADTCivilACADM
17.7.2009
15966×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD LT · AutoCAD Architecture · Civil 3D · AutoCAD Mechanical ·
