CAD tip CAD tip # 10808:
Question
AutoCAD version 2017 dropped support for the "transparent" RGB color 192/192/192 in BMP files. You need to use true transparent PNG bitmaps for your custom icons.
You can batch-convert your existing BMP icon files to transparent PNG files using the IrfanView viewer (free) or any other bitmap editor. Use the following command line to convert the BMP with IrfanView:
"C:\Program Files (x86)\IrfanView\i_view32.exe" MyIcon.BMP /transpcolor=(192,192,192) /convert MyIcon.PNG
You can even leave the original icon names in your .cuix file - any PNG-format picture file renamed to the .BMP extension will load smoothly into your AutoCAD 2017 ribbon.
ACAD2017ACLT2017ADT2017
24.3.2016   15896×
this tip shared by ARKANCE experts applies to: AutoCAD 2017 · AutoCAD LT 2017 · AutoCAD Architecture 2017 ·
Tip 14542:How to easily add a transparency toggle in AutoCAD?
Tip 14417:Quick calculator on an AutoCAD keyboard shortcut.
Tip 13557:How to create an image with transparent background in Fusion 360?
Tip 10062:Empty (white/transparent) Quick Access Toolbar - QAT.
Tip 6546:How to set transparent color for my own AutoCAD icons?
Back    All CAD Tips
Categ:
