CAD tip CAD tip # 8133:
Question
ABB RobotStudio supports among others the CAD formats ACIS and IGES. So in AutoCAD, export your 3D DWG model to the file format SAT or IGS using the commands ACISOUT or IGESEXPORT.
ACADDWG
8.8.2011   18223×
this tip shared by ARKANCE experts applies to: AutoCAD · DWG ·
Tip 14833:CAD formats supported in Autodesk VRED 2026.
Tip 12588:Which CAD formats can be be translated in Fusion 360 even without the cloud, offline?
Tip 12325:How to display a DWG from Advance Steel including AS objects? (AST viewer)
Tip 12297:Which CAD formats are supported in the Autodesk Manufacturing Data Exchange Utility?
Tip 9528:Using Autodesk Fusion 360 as a CAD converter.
Back    All CAD Tips
Categ:
