CAD tip CAD tip # 11821:
Question
How can I preset the page names when publishing a DWG drawing to PDF? I need to change the format "file name-layout name" to strictly a plain "layout", resp. to the page number.
Page names in a PDF file are dependent on the plot/publishing method. If you use the PUBLISH command and if you uncheck the option "Prefix sheet title with file name", all pages will be named just the same as the layouts.
And the layouts can be even named automatically by a given attribute in your title blocks (e.g. the page number) - see the Tip 11780.
ACADACLT
5.3.2018   13737×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD LT ·
Tip 14958:A PDF drawing from Revit or AutoCAD does not print exactly at a 1:1 scale.
Tip 14709:How to export Fusion drawings to AutoCAD (DWG)?
Tip 14604:QRcode - dynamically generated QR codes in AutoCAD.
Tip 14481:How to bulk publish a folder of DWG/DXF files to PDF?
Tip 13778:How to publish several DWG drawings into one multi-page PDF?
Back    All CAD Tips
Categ:
Take advantage of orthophotos, point clouds, and design files. Get better quality design changes faster with Pointscene More info
