Over 1.127.000 registered users (EN+CZ).
CAD tip # 9012:
Question
When you want to change the name of a view, detail, or section in an Inventor drawing sheet, you can do it with the context menu. Right-click on the target view and choose "Edit View" from the gesture menu. Then change the value of "View identifier" in the View dialog.
Another option for renaming a view is changing it directly in the browser tree - long-click on its name.
Inventor
9.1.2013
17076×
this tip shared by ARKANCE experts applies to: Inventor ·
