Over 1.127.000 registered users (EN+CZ).
CAD tip # 8441:
Question
If you need to suppress (hide, disable) display of sketch simensions in the Inventor Sketch environment, you can use the following simple VBA macro. Insert it in the active document (or template) in the VBA Editor.
You can run it with Alt+F8 or add it to your ribbon (see):
Sub ToggleDims() Dim oDoc As PartDocument Set oDoc = ThisApplication.ActiveDocument oDoc.ComponentDefinition.Sketches(1).DimensionsVisible = Not oDoc.ComponentDefinition.Sketches(1).DimensionsVisible End Subor an alternative macro which can be stored anywhere:
Sub ToggleDims2()
Dim oSketch As PlanarSketch
On Error Resume Next
Set oSketch = ThisApplication.ActiveEditObject
If Err.Number <> 0 Then Exit Sub
On Error GoTo 0
oSketch.DimensionsVisible = Not oSketch.DimensionsVisible
ThisApplication.ActiveView.Update
End Sub
Outside the Sketch environment just right click on the sketch in the browser and set Dimension visibility.
Inv2012Inv2011Inv2010
27.1.2012
25863×
