CAD tip CAD tip # 9659:
Question
You can use iLogic code to automatically adjust parameters of your Inventor model to yield a specific volume or mass of the model. You can use it in iteration loops without calculating the volume mathematically.
This is a concept - a sample code accessing and increasing the d1 parameter by 10% while checking the resulting Volume of the model (you can replace it with Mass):
ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd").Execute
myVolume = iProperties.Volume ' or Mass
MessageBox.Show("Volume before = " & myVolume, "iLogic")
d1 = Parameter("d1")
MessageBox.Show("d1 before = " & d1, "iLogic")
Parameter("d1")=d1 * 1.10
ThisDoc.Document.Rebuild()
MessageBox.Show("d1 after = " & d1, "iLogic")
MessageBox.Show("Volume after = " & myVolume, "iLogic")
Inventor
22.1.2014   9582×
this tip shared by ARKANCE experts applies to: Inventor ·
Tip 15073:How to run an iLogic rule from the ribbon or with a keyboard shortcut?
Tip 14975:iLogic Codeblocks - visual programming in Inventor 2027
Tip 14641:Automatic naming of Inventor drawing sheets according to the first model (iLogic).
Tip 14634:Physical units conversion tool in an Inventor palette.
Tip 14611:Contribution of individual features to the total mass of an Inventor part (iLogic).
Back    All CAD Tips
Categ:
