Over 1.096.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 9721:
Question
If you want quickly switch off all layers except of specified layers - e.g. all but layers staring with "E-", or all except xrefs - you can use an inverse filter (swung dash, tilde, "~").
You can use your inverse filter for layer filtering in the Layer Manager or directly in the LAYER command.
So you can e.g. add the following command to your menu:
(command "_layer" "_OFF" "~E-*" "")
(switches off all layers but those starting with "E-"; mind the "0" layer)
Or enter this to the layer filter:
(selects all layers but xrefs)
ACADACLT
4.3.2014    12405×
applies to: AutoCAD · AutoCAD LT ·
Tip 14163:How to select DWG texts containing a certain number of characters?
Tip 13878:SelectSimilar - extended selections for AutoCAD, incl. LT and Web versions
Tip 13855:DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder.
Tip 13688:How to select all DWG objects of a certain type in AutoCAD LT? (texts, circles...)
Tip 13442:How to easily count the number of certain objects in a DWG drawing in AutoCAD LT?
Back    All CAD Tips
Categ:
