Over 1.126.000 registered users (EN+CZ).
CAD tip # 9248:
Question
You can use many arithmetic and goniometric functions in calculated paramaters of Inventor models:
+ addition - subtraction % modulo * multiplication / division ^ power () expression delimiter ; argument delimiter
Supported function:
cos(expr) sin(expr) tan(expr) acos(expr) asin(expr) atan(expr) cosh(expr) sinh(expr) tanh(expr) acosh(expr) asinh(expr) atanh(expr) sqrt(expr) - square root sign(expr) - signum 0/1 exp(expr) - e^x floor(expr) - next lower integer ceil(expr) - next higher integer round(expr) - round to integer abs(expr) max(expr1;expr2) min(expr1;expr2) ln(expr) - natural logarithm log(expr) - decimal logarithm pow(expr1; expr2) random() - random number isolate(expr;unit;unit)
Please note that all expressions must be unit-compatible.
Inventor2014
14.5.2013
40371×
this tip shared by ARKANCE experts applies to: Inventor 2014 ·
