Over 1.127.000 registered users (EN+CZ).
CAD tip # 9305:
Question
If you get the "Unable to create component" error when trying to insert a component from a local Content Center, or if Inventor still inserts an old, outdated version of a component after you updated it (or its thumbnail) in the Content Center, clear the local cache of your Content Center.
This cache is stored in the folder (by the Inventor version):
C:\Users\USERNAME\AppData\Local\Autodesk\Inventor 2013\Content Center\CMCache
or (WinXP):
c:\Documents and Settings\USERNAME\Application Data\Autodesk\Inventor 2013\Content Center\CMCache
Rename or delete this folder and restart Inventor.
Inventor
19.6.2013
16716×
this tip shared by ARKANCE experts applies to: Inventor ·
