Over 1.127.000 registered users (EN+CZ).
CAD tip # 8142:
Question
The error message (warning) "Line is too short" indicates an underflow of the value with the minimal length of the geometry as supported by Revit.
Due to the internal representation of the object sizes, the minimum line length in Revit is limited to 1/32", resp. 0.75 mm.
This error usually indicates another problem in the drawing (e.g. an invalid coordinate entry).
Revit
16.8.2011
17071×
this tip shared by ARKANCE experts applies to: Revit ·
