CAD tip # 9739:
Question
If your DWG file size increases a lot (compared to the originally opened file) when saved from AutoCAD (2012, 2013 or 2014) - up to multiples of the original size - it is most probably caused be processing of complex linetypes from a DGN file. Aply the DGN Hotfix -
Download - and then run the DGNPURGE command.
Other causes of smaller increases of the DWG file size:
- Setting an older version of the DWG file format as the default (e.g. DWG2000 in AutoCAD 2014) - see Options
- Processing AEC objects - try the command -EXPORTTOAUTOCAD
- Processing other proxy objects - see SAVEFIDELITY
- Saving thumbnails in high resolution - lower THUMBSIZE (see the tip 8754)
- The incremental save mechanism - see ISAVEPERCENT
- Anonymous objects - perform PURGE (or see tip 9553)
- The original drawing file is not in the genuine DWG format
ACADACLTADTACADMCivilMapPlant
17.3.2014
32203×
