Over 1.103.000 registered users (EN+CZ).
New AutoCAD 2026 commands and sys.variables and env.variables,.
CAD tip # 7289:
Question
The help system in AutoCAD 2011 uses the online help on Autodesk web site. If you want to switch (toggle) the help function back to the local files in the folder C:\Program Files\Autodesk\AutoCAD 2011\Help, change the setting in the AutoCAD Options.
In the Options dialog (OPTIONS, A > Options), on the System tab, uncheck the option "Use online help from Autodesk website when available" in the Help pane.
The current setting of this option is trored in the undocumented variable WBHELPONLINE.
ACAD2011ACLT2011ADT2011Civil2011
29.3.2010
14418×
