CAD tip CAD tip # 8640:
Question
Paragraph texts in AutoCAD can contain control codes which influence appearance of the text. These formatting control codes are automatically inserted in the internal MText editor. But if you edit your texts with an alternative editor (e.g. Notepad), or if you generate them programmatically, you can use these codes to format your paragraph texts.
CodeFunction
\LStart underline
\lStop underline
\OStart overstrike
\oStop overstrike
\KStart strike-through
\kStop strike-through
\NNew column
\PNew paragraph (new line)
\pi \pxi \pxt \pxqControl codes for bullets, numbered paragraphs, tab stops and columns - e.g. bullets: \pxi-3,l3,t3;, tab stops: \pxt10,t12; (l=left offset, t=tab spacing), justification: \pxql;=left, \pxqr;=right, \pxqc;=center, \pxqj;=block-justified, \pxqd;=distributed
example:
  • \pxi2,l0.8,r3.2,b0.3948,a0.2616,se0.492;=indent first 2 lines of the paragraph from left/right, spacing before and after the paragraph, line spacing exactly (e) or multiples of (m) the given value (values always in inches)
\XParagraph wrap on the dimension line (only in dimensions)
\QSlanting (obliquing) text by angle - e.g. \Q30;
\HText height - e.g. \H3x;
\WText width - e.g. \W0.8x;
\FFont selection
  • e.g. \Fgdt;o - GDT-tolerance
  • e.g. \Fkroeger|b0|i0|c238|p10 - font Kroeger, non-bold, non-italic, codepage 238, pitch 10
\SStacking, fractions
  • e.g. \SA^B:
    B
  • e.g. \SX/Y:
    X
    Y
  • e.g. \S1#4:
    ¼
\AAlignment
  • \A0; = bottom
  • \A1; = center
  • \A2; = top
\CColor change (ACI colors)
  • \C1; = red
  • \C2; = yellow
  • \C3; = green
  • \C4; = cyan
  • \C5; = blue
  • \C6; = magenta
  • \C7; = white
You can also use \c and a combination of ACI color index and truecolor long code or color book (see color converter) - like this:
  • \C113;\c10601021; = greenish
\TTracking, char.spacing - e.g. \T2;
\~Non-wrapping space, hard space
{}Braces - define the text area influenced by the code
\Escape character - e.g. \\ = "\", \{ = "{"
Codes and braces can be nested up to 8 levels deep. Formatting codes can be removed via the context menu in the MText editor.
ACADACLT
21.5.2012   119583×   FAQ
this tip shared by ARKANCE experts applies to: ACAD · ACLT ·
Tip 15147:Displaying the value of a text field, including the sign (incl. the '+' sign)
Tip 15138:AutoCAD Field formatting codes - full list.
Tip 15070:Parametric labeling/numbering in AutoCAD Electrical.
Tip 15059:Undocumented drawing variables in Autodesk Fusion.
Tip 14560:JobTime for Autodesk Fusion - tracking time spent on a job.
Back    All CAD Tips
Categ:
