CAD tip CAD tip # 9202:
Question
You are experiencing an offset or wrong scale of the imagery brought into your DWG drawing with the AutoCAD geolocation function (LiveMap). A building footprint appears smaller or larger than the live map data.
Make sure you have choosen the right "Drawing units" and "GIS Coordinate System" in the Geographic Location dialog. Your DWG objects may use other units/scale or another CS.
ACAD2014ACLT2014ADT2014Civil2014Plant2014
16.4.2013   17810×
this tip shared by ARKANCE experts applies to: AutoCAD 2014 · AutoCAD LT 2014 · AutoCAD Architecture 2014 · Civil 3D 2014 · AutoCAD Plant 3D 2014 ·
Tip 14969:Examples of AI prompts and the challenges of using the Autodesk Assistant AI feature for analyzing and generating CAD geometry in AutoCAD and Fusion.
Tip 14894:Importing CSV points in Map/Civil - ImportPoints vs. MapImport.
Tip 14718:Activating contextual learning in Eagle Point Pinnacle.
Tip 14565:MAPIINSERT in version 2026 ignores georeference from the World file.
Tip 14468:How to connect Bing Maps in AutoCAD 2026 (and higher)?
Back    All CAD Tips
Categ:
