Over 1.124.000 registered users (EN+CZ).
CAD tip # 9149:
Question
With the free LISP utility CADstudio AddArea you can easily summarize the total area (acreage) of all selected polygons, regions, hatches, circles and other drawing objects with the "area" property in your current drawing.
Download. Then run it with the AddArea command.
The areas are also grouped by layers. Optionally, you can export the results to a SDF text file or to the Clipboard. You can also list individual values (areas). The number of decimal places depends on the UNITS command.
Sample output:
Layer-Area: 0 118.1143 PAVEMENTS 438.91 VEGETATION 1311.08 WATER 3010.72You can download the AddArea utility from
You can use LISP variables to control the format of text output:
(setq AddAreaNoSub T) ; suppress subtotals
(setq AddArea3rows T) ; layer in 3 rows
(setq AddAreaNoFile T) ; no export to SDF file
(setq AddAreaDecimals 4) ; set decimal places (LUPREC by default)
(setq AddAreaObjTypes "HATCH,LWPOLYLINE") ; filter selection to just these object types
(setq AddAreaSortSub T) ; sort detailed areas from the largest
(setq AddAreaClipMode 1) ; output results to Clipboard (1=incl.layer name, 2=just areas)
Spaces in layer names are replaced by "_".
We offer a similar utility for lengths - see AddLen.
ACADADTACADMCivil
15.3.2013
31861×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD Architecture · AutoCAD Mechanical · Civil 3D ·
