Over 1.124.000 registered users (EN+CZ).
CAD tip # 9910:
Question
The maximum number of displayable points in point clouds imported resp. attached (POINTCLOUDATTACH) into AutoCAD from the capture application Autodesk ReCap (.rcp) is 25 million in AutoCAD 2015 (in AutoCAD 2014/2013 it was 10 million). For 32-bit versions of AutoCAD (and for AutoCAD 2012/2011), this maximum is at 1.5 million points. Point clouds in old legacy file formats have a maximum of 10 million points.
This limitation applies as a total of all points clouds attached in the respective drawing. The setting is stored in the POINTCLOUDPOINTMAX variable (POINTCLOUDPOINTMAXLEGACY for legacy formats)).
For setting go to Options > 3D Modeling:
ACAD2015ACAD2014ADTCivilMapPlant
17.7.2014
14259×
this tip shared by ARKANCE experts applies to: AutoCAD 2015 · AutoCAD 2014 · AutoCAD Architecture · Civil 3D · AutoCAD Map 3D · AutoCAD Plant 3D ·
