CAD tip # 12470:
applies to: AutoCAD · AutoCAD Architecture · AutoCAD Plant 3D · AutoCAD Mechanical · Civil 3D · AutoCAD Map 3D · |
Tip 13737: | Formatting leading zeros in AutoCAD fields (and automatic field update). |
Tip 13522: | LookupXLS - populating DWG texts from Excel spreadsheets. |
Tip 12837: | RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables |
Tip 12743: | A change in iLogic processing of Excel tables since Inventor 2021. |
A trick for easier text editing in Revit.
What for is the Bank option of the SWEEP command? « | » How much water is boiling in the Utah teapot?
