CAD tip # 12471:
applies to: AutoCAD · |
Tip 13965: | Total length of sweeps in Inventor - wires, pipes, trusses, tubes, hoses (iLogic) |
Tip 13358: | Restore the last deleted entity in the DWG. |
Tip 13040: | iLogic - display information about complexity of an Inventor part. |
Tip 13006: | Calculated property descriptions (tobogan slide from floor to floor) |
Tip 12600: | Parametric 3D curves in Fusion 360. |
Entering Inventor angles in degrees, minutes, seconds.
Mysterious text rotation when editing. « | » A table with calculated expressions is suddenly dead, doesn't calculate and update.
Featuring: Automatic nesting of 2D parts on rectangular sheets in AutoCAD AutoNEST 2008 |
