Over 1.124.000 registered users (EN+CZ).
CAD tip # 8763:
Question
If you get only a hollow rectangle (frame) instead of the dimension text, check the setting of the QTEXTMODE variable.
Set it back to 0 if neccessary and issue a Regen. Check also settings of the dimension style.
ACADACLT
16.8.2012
11623×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD LT ·
