CAD tip CAD tip # 8534:
Question
On AutoCAD startup, this message appears: AutoCAD requires 1024x768 resolution or higher to run. But your screen resolution is much higher.
Select your AutoCAD desktop icon, pres Alt+Enter and look in the Compatibility tab. You might have the "640x480" option checked by mistake or as a practical joke...
Check also your Windows font size settings. Start the Windows Control panels and check the setting Display (Appearance and Personalization > Adjust screen resolution), custom text size (dpi) - it should stay on 100%, not 150%.
Credit: D. Gelissen
ACADACLT
21.3.2012   42833×
this tip shared by ARKANCE experts applies to: ACAD · ACLT ·
Tip 14349:12 free material texture libraries for PBR rendering.
Tip 12779:How to export a hi-res image from Autodesk Infraworks?
Tip 12609:Dynamo - how to convert a raster photo to 3D model in Revit?
Tip 11818:How to change resolution of images in the Clash Detective report in Navisworks?
Tip 11806:Higher precision for facetted round surfaces in STL export from Inventor.
Back    All CAD Tips
Categ:
