CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 1825
CAD tip CAD tip # 8538:
How to open a PDF file from AutoCAD?
A - answer If you need to open a PDF document (e.g. a manual or a product specification) directly from AutoCAD, you can use the START command (defined in ACAD.PGP):
START C:\Docs\MyDocument.pdf
This will invoke your default PDF reader (e.g. Adobe Acrobat Reader) with the specified PDF file. You can use the same approach for any other file type (Excel, PowerPoint, video, ...).
ACADLT
25.3.2012    6159x
Comments   Tell a friend
applies to: AutoCAD · AutoCAD LT ·
Tip 8788:Batch unification of page setups in DWG files.
Tip 8532:Import of 3D DWF files back to editable 3D models.
Tip 8501:How to avoid opening Acrobat Reader after publishing DWG to PDF?
Tip 8104:File formats supported in Autodesk Navisworks 2012.
Tip 7586:Convert PDF files to the DWF or DWFx format.
Setting command line background color from LISP. « | » AutoCAD requires 1024x768 resolution or higher to run.
Need easy intranet document management? Try iPROJECT More info
